I would check for a vac leak first as those usually work well..could be in the line from the engine to the booster..maybe as simple as a loose connection or maybe the vac line has a hole in it or it has contacted a header..
Sam
Because it has disc/drum there should be a 10lb residual valve in the rear line and a 2lb valve in the front. If they are not there, then you may have a problem down the road with a very spongy pedal if you have a pedal at all.
Sounds like probably a bad booster,
The brakes seem to work well, but there appears to be no power assist whatsoever. The vacuum assist unit is definitely hooked into manifold vacuum, as you can feel and hear the engine react when you press the pedal. In fact, after a long brake application, the engine (1987 Corvette 350 TPI) stumbles significantly, as if sacrificing great gobs of vacuum. The engine idles fine otherwise, although I have yet to check it at idle with a vacuum gauge
What you are describing is exactly what happens when the diaphragm in the booster has failed. If the diaphragm was good the engine would only react for a brief instant . I found a great booster made for hot rod apps on e-bay for less than $90 which works great on my T-bucket . |
Adantessr, would you happen to have a link to more information on that booster for hot rod apps you mentioned? Thanks again. Cheers, Ken |
OK, folks, did some inspecting and testing:
The booster doesn't seem to be holding any residual pressure. I performed a basic test (turn off engine, pump pedal to remove residual, re-start to see if the pedal drops). The pedal would not drop. Zero. I will start by replacing the check valve tomorrow. Looks like a standard item - hopefully. Regarding the rest of the setup, I climbed underneath and got some information. The MC is stamped "29969", and I know from past experience that is a late 60's - early 70's GM application. The power booster measures 8" in diameter, and is stamped ABS. I believe ABS is a manufacturer of power brake conversion kits. Not crazy at all about how close the exhaust pipe is to the power booster - the exhaust heat can't be any good for the booster. ![]() ![]() ![]() Not sure if this is any sort of check valve or not, it is mounted inline in the front disc brake line: ![]() The vacuum feed splits off at the transmission to feed both the vacuum modulator on the Turbo 350 and the power brake booster - not sure if that's kosher? ![]() Thanks for everyone's advice up to this point. Appreciate any more comments and information. Cheers, Ken |
Hello folks,
This afternoon I confirmed the problem - a defective power brake booster. The replacement part is on order from a local supplier, I expect it by tomorrow. It appears that the reason it failed may have something to do with the close proximity of the exhaust pipe, it was actually in contact with the booster. That is unacceptable, so I have removed the entire exhaust system and will have it redone by a local rod shop as soon as the new booster is installed and the brakes are fixed. Thanks to everyone who responded - I sincerely appreciate the assistance and support. Cheers, Ken |
Hello again folks,
OK, I replaced the vacuum booster - what a difference! At least I don't have to stand on the brakes anymore, and my wife can drive the car now. Follow-up question...I suspect that my MC lines may be reversed. The reservoir closest to the booster is connected to the front disc brakes, and the one farthest from the booster is connected to the rear drum brakes. Could this make a difference? Is there a difference in the pressure output between the front and rear reservoir? I want to make sure I get the most performance possible out of the system. Thanks in advance. |
My MC is a Corvette style, with both reservoirs of equal dimension. But on the MPB website... http://www.mpbrakes.com/uploads/docu...lumbingpdf.pdf ..they specify exactly which circuit goes to which port as if it would make a difference...
| Turbo vs Supercharger - Write up!! | FastChevyTruck | Engine | 107 | 02-16-2011 12:18 PM |
| 68 firebird power drum brakes pushrod | vwspeedwagon5 | Suspension - Brakes - Steering | 2 | 08-15-2008 06:34 AM |
| Disc brakes without power booster? | KNanthrup | Suspension - Brakes - Steering | 10 | 01-10-2008 09:02 PM |
| Manual vs Power rack and pinion | oldguy829 | Suspension - Brakes - Steering | 20 | 09-05-2007 02:58 PM |
| power or manual mustang rack | americanLT1 | Suspension - Brakes - Steering | 2 | 11-13-2004 04:34 AM |
