Power Brakes, im confused
Well i just rebuilt my suspention and added power disc brakes from the old manual drums. I got it all in and aligned. When i bleed the lines and took it for a test drive, it felt really bad, i almost drifted into an interestion. My question is do i have to bleed the brake with the motor running for vacumn reasons. Or is there a certain way i need to bleed the brakes, or does anyone know of anything that could be bad. Please help, thanx
Do you have a single reservoir master cylinder? I'd upgrade to a dual reservoir. For bleeding them i have a drinkin' buddy pump the brakes 5 times and hold the pedal while i crack the bleeder open (they gotta earn that beer somehow!!) repete it a couple of time for each caliper.
C |
its a dual, but i though i got all the air out, im just wonderin if the vacum has somethin to do with it, or is there a certain way im suppossed to bleed the brakes.
Did you bench bleed the master?
what does bench bleed mean? because i dont think i did it.
You have to bleed the master cylinder. You fill up the bowls, and there's a tube that you can buy at Kragen's for a couple bucks that sends the brake fluid out the master and back in the bowl when you pump it. You keep pumping it until there's no more bubbles going through the clear tubes. I don't know if this is the cause of your problem, but are your brakes acting like they have air in the system? If so, that could be it. Also, to answer your question, you don't need the car running to bleed the brakes.
Dot 3 and dot 4 are compatable so don't worry about that. Also don't worry about not bench bleading the master cylinder all it does is speed up the bleeding process but its no nessicary. It could be a situation where you have insufficent boost which would be my guess here. How low does the petal go? if it is at normal high when you stomp on it then it probably is the insufficent boast situation. Did you use a donar car? Oh one other thing no the car does not have to be running to bleed the brakes with vac assist
well i think we narrowed it down, we have bled the lines so much the liquid comming out is clean like just poured in the master cylinder. But we noticed the brake pedal pressure doesnt change if the vacumn line is hooked up, or not hooked up to the booster. So i thing the booster is bad. The funny thing is we bought it brand new. Damn *******s, lol. If anything else could be causeing this problem please let me know but for right now were gonna exchange the booster and see if another one will work.
keep us posted on how it goes good luck
to bizkit075
did you fix your brakes??? |
