Power Brakes upgrade - what is the reason for disc/disc, disc/drum & drum/drum - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2012, 09:27 PM
I've got a 1957 GMC 9300 (Chevy 1/2 ton) with 4 wheel drums. Soon, I'd like to upgrade to IFS which would include an upgrade to disc brakes. Eventually I would like to upgrde to disc brakes in back too. But for now, I want to simply upgrade to power brakes.
The power brake kits are available for Drum/Drum, Disc/Drum, and Disc/Disc applications. Why is there a difference? Is it simply the proportioning valve? or is there something else like ti will blow the brake cylinder in the drum brakes. I was going to simply order the Disc/Disc kit but am leary.
PS. I'd call them, but it's usually late and they are closed.
Thanks,
Mike
Old 10-20-2012, 01:14 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
generally its the residual valve thats in the master cly that keeps a small amount of pressure on the drum brakes.Its not needed on disc brake set ups. On most master cly its just a matter of going into the master cly and removing it if not needed.
Old 10-20-2012, 09:44 PM
Wiki Edits: 27
chamber volume.
chamber volumes are different for the Dual chamber M/cyls, depending what it is, I have heard of one of the chambers going dry when you apply the brakes with the wrong M/C
disc, drum, master cylinder, power brakes
master cylinder for drum/drum or disc/drum GMR Suspension - Brakes - Steering 5 07-23-2012 10:11 PM
Will a Brake Master Cyl. Designed for Disc/Drum be Adequate for 4-Wheel Disc Brakes? mrwumper Suspension - Brakes - Steering 3 04-16-2009 10:38 AM
Power boost drum brakes vs. disc brakes??? woodscavenger Hotrodding Basics 13 08-08-2007 03:07 PM
Disc/Disc vs Disc/Drum master cylinders rlvirago Suspension - Brakes - Steering 6 02-28-2007 04:33 AM
Master cylinder: Disc/drum vs. drum/drum wp442 Suspension - Brakes - Steering 4 09-28-2004 03:46 PM
