Power disc brakes from Nove with tilted master cyl ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2014, 02:48 PM
I have a 49 chevy that I clipped from a rear stear Nova in 1989. when I clipped this i swaped to power disc brakes with swinging peadles from the nova, every thing worked out just fine. I just took it out of storage and the P/B booster is bad,so it needs to be replaced. The questain is I would like to instal a P/B booster that mounts level with engine, instead of at a angle like the Nova is , this booster is about 11 inches in diameter ,with swinging peadles from the Nova,if I instal booster that is horzontal mounted will I need to change the fulcrum point on the brake peadle ? and what parts do I need. Thanks in advance Larry ( an OLD HOT RODER from the 60sties)
How to ID master cyl disc frt/drum rear cyclopsblown34 Suspension - Brakes - Steering 2 09-18-2010 08:05 PM
Will a Brake Master Cyl. Designed for Disc/Drum be Adequate for 4-Wheel Disc Brakes? mrwumper Suspension - Brakes - Steering 3 04-16-2009 10:38 AM
Master cyl. for drum brakes kreuzn1 Suspension - Brakes - Steering 6 04-26-2008 08:17 PM
Stock Monza Master Cyl work with aftermarket disk brakes? Quarter Flash Suspension - Brakes - Steering 1 11-19-2006 06:31 PM
Dual master cylinder for drum/disc brakes wiretwister Suspension - Brakes - Steering 4 02-16-2003 09:56 AM
