power disc woes...or not so much woahs... - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2009, 09:13 AM
usmcsawgunner's Avatar
so i had my 64 f-100 up on fron truck ramps redoing the wiring harness for about a week or so and i get it all done and now the power brakes feel like the booster isnt working. (its 74 nova front disc) the only thing i did differently with the vacuum lines is i tied in a vacuum gauge to the booster line. would that do it? thats how the autometer instructions say to do it.
by the way my vacuum gauge is showing about 5 in. in park and about 3 in drive. i tried spraying starting fluid aroud everywhere and i cannot find a leak. what the heck??
Old 02-04-2009, 10:15 AM
RetroWill's Avatar
That isn't even close to enough vacuum to get assist from the booster. Something is wrong, you need at LEAST 15 inches of vacuum in most cases. You either have something kinked or restricted to cause that low reading. Better have a good look-see at everything in the vac. supply.
Old 02-04-2009, 01:57 PM
yea will do
Old 02-04-2009, 02:13 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
connect a vac gauge at the carb see what you have there..then work your way out each connection until you get a big vac drop..then you know where the leak is..or have a better idea..
Sam
Old 02-04-2009, 02:18 PM
i love simple little tricks like that....wish i could think of some of those once in a while...
Blower Carb Boost Referenced power valves steve392 Engine 18 01-23-2012 01:06 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
drum to disc conversion kits dmented Suspension - Brakes - Steering 4 06-06-2007 10:06 PM
Car Audio Question Thuggishruggish3000 Interior 14 12-23-2003 09:48 AM
67 camaro power drum to disc donor cars whosh Suspension - Brakes - Steering 0 02-17-2003 11:02 AM
