Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - power distribution too many wires for my solenoid
Old 08-20-2012, 05:32 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by sknitsloa View Post
I am looking for a power distribution block. I have too many power leads for my solenoid and I'm eliminating the solenoid anyway.
Somewhere I saw something that mounted to your frame rail or inner fender with 2 bolts and then a single threaded with a nut sticking out to attach all your power leads and battery cable.
I am not looking for a battery terminal to go through the firewall.
Thanks for the help!
Is the distribution block in addition to, or instead of, a fuse box? Reason I ask is because all the wires need to be protected in some way (fuse, circuit breaker, fusible link) anyway, so it might be easier and more efficient to use a small auxiliary fuse box like mentioned in the thread: Ideas for race car wiring.
If the circuits are sufficiently protected the way they are now, the simpler blocks like shown can be used. The double block's terminals can be connected together w/a copper lug if extra capacity is needed.
