power door locks - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2007, 05:41 PM
power door locks
I would like to put power locks in my 85 F150 as inexpensively as possible
Does any one know how the wiring from switch to lock to unlock works?
I had planned to visit the local bone yard and scavenge some locks and switches but some switches I've looked at have 5 and 6 wires running from them ?????Or am i stuck replacing the interior harness or buying a aftermarket
kit ....I would appreciate any help thanks.
Old 04-27-2007, 08:58 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
The switches for a door lock system are just simple reverser switches. Double pole, Double throw, Double row Switches..(Lock/Off/unlock)
If you look at the diagram, it shows the power and ground is reversed at the switch depending on the state of the switch one way opens the lock (power) the middle position (is off) the other position (ground) closes the lock.
To be honest, I'd get a kit, for one main reason, from a bone yard the Solenoids and Switches most likely won't have a long life..The fail regularly in optimum Conditions because of the abuse they must endure (water from the window gaskets leaking, Condensation, your coffee spilled on the switches) AND who knows what bone yard stuff went through in previous life..
A Kit is Cheap enough, under about $200 Fazools, IS NEW, and Made to fit your Car With INSTRUCTIONS! and will probably last a lot longer than a Cobbled up system of bone yard parts.modified to "Almost" work with your car..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 04-28-2007, 10:40 AM
vicrod's Avatar
life is a ride
Last journal entry: 2014
These folks make a good remote door lock system.
www.autoloc.com
vicrod
Old 04-28-2007, 11:29 AM
galaxieguy3's Avatar
When I did my Galaxie, I bought actuators and relays off Ebay, and wired it through a Bulldog alarm system for remote door locks. I think the actuators were under $10 each and the relays with wire whips were about $10 for a pair. Then all you need is a switch or 2, which I am guessing you can probably get on ebay also.
Old 04-29-2007, 08:38 PM
Last wiki edit: Window removal and installation Last photo:
Wiki Edits: 11
With an 82-6 F-Series truck you are in luck. A junkyard swap is THE way to go.
Find your donor truck or similar year Bronco and remove both door harnesses. No such thing as power locks without power windows but you don't have to install them to get locks. The main harness runs under the top dash pad you only have to remove the pad to feed /wiggle it out. The wires clip into the back of the fusebox. You need a tiny screwdriver ot something like an icepick. You can get these wires to release and they will clip right into the back of your fusebox. Don't forget to grab the relays power windows and locks use instead of fuses.
The door lock motors are annoyingly riveted into the door shell with a big aluminum rivet. You'll need to drill or chisel it off. You'll likely have to take the latch loose to get the motor to unhook from it. Your door latch should have the appropriate hole for it to attach to. Also a hole where the lock motor will be riveted.
The whole deal is almost plug and play. You don't have to figure out wiring, just connect it up. When you get done, the only thing keeping you from having power windows too is getting the regulators with the motors and the switches. The only reason I added power windows is because I can't reach across the truck to operate the passenger window. Something to consider. If you don't want them I would just tie the door harnesses out of the way and leave them. You might change your mind later.
Some folks cut their door panels. I was lucky enough to score a pair of panels the correct color for my swap.
The whole setup is almost plug and play.
Pully problems: sbc 671 weiand, power steering malibu68 Engine 1 12-05-2006 11:09 AM
Swapping to big block chevy low77ride Engine 5 09-15-2004 10:30 PM
Advise on Porta Power choice meanroy Body - Exterior 7 06-24-2004 12:38 AM
Unusual Power Steering Conversion Lars Sorensen Suspension - Brakes - Steering 17 05-25-2004 03:05 PM
power brakes and power steering on a '63 impala SS Benni520 Hotrodders' Lounge 2 10-14-2002 10:49 PM
