power drum brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2010, 01:11 PM
power drum brakes
i have a 72 chevelle with drum brakes and was thinking of changing the master and adding a booster i know it will work but is it worth it , thanks
Old 12-21-2010, 01:59 PM
ericnova72's Avatar
More for Less Racer
What are your goals fro this swap??
If you are thinking it will improve stopping distance or brake fade,...it won't. All it is going to do is reduce pedal effort for the driver(that is what a power brake booster does), the actual braking is done by the pads and he drums and nothing has changed there.
Much smarter move would be to swap to front disc brakes, leaving the master cylinder a manual brake set-up. This will improve stopping distance and brake fade.
Old 12-21-2010, 02:29 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
^^^^ nail on the head
Old 12-21-2010, 04:57 PM
brakes
thanks are baer disc brake kits good i understand you don't replace your old spindels
68 firebird power drum brakes pushrod vwspeedwagon5 Suspension - Brakes - Steering 2 08-15-2008 07:34 AM
Power boost drum brakes vs. disc brakes??? woodscavenger Hotrodding Basics 13 08-08-2007 03:07 PM
Weight of Disc Brakes vs Drum Brakes leejoy Suspension - Brakes - Steering 7 06-29-2007 01:41 AM
drum brakes mitmaks Suspension - Brakes - Steering 2 07-31-2004 02:59 AM
911 Brakes, Master Power Drum Brake Upgrades? frankenvette Suspension - Brakes - Steering 1 07-14-2004 09:04 PM
