Power glide issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2012, 08:28 AM
Power glide issue
I have a power glide trans in a race car. Took it to the track this weekend and it started blowing fluid out when put into reverse. Any ideas on what this might be. Only thing I can think of is could be stopped up and blowing out the vent in the top.
Old 03-19-2012, 10:28 AM
Sounds like you got a reverse servo seal blown. Is it a trans brake or what?
Old 03-19-2012, 10:48 AM
Yes it has a trans brake. Buddy of mine said it could be a cracked case. Just had me puzzled only leaking in reverse.
Old 03-19-2012, 06:27 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
A common fracture area on the OEM power glide case is at the rear in the area of the reverse piston in a race type use.
When the reverse piston is pressurized , the oil escapes in the crack.
To Power Glide, Or not to Power Glide 68Elcamino Transmission - Rearend 3 06-25-2010 05:59 AM
T-400 or Power glide ? 70ss454 Transmission - Rearend 5 10-20-2008 06:04 PM
350 Power glide chappell Transmission - Rearend 4 03-21-2008 10:47 AM
Power Glide jmbjs Transmission - Rearend 7 04-21-2007 01:30 AM
power glide? nitro_baller4692 Transmission - Rearend 1 09-24-2006 04:19 PM
