power glide jumps out of drive - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2011, 07:58 PM
i have a '72 nova with a power glide, and if i punch it from a stop it jumps out of gear, if i take off easy its fine. any suggestions?
Old 09-16-2011, 08:01 PM
junior stocker's Avatar
Possibly a broken motor mount that allows the engine to torque over, bind up the shift linkage, and pull it out of gear?
Old 09-16-2011, 08:04 PM
just bought the car, the guy did say he thinks the motor mount was broken... i will try that first, thanx alot!
Old 09-17-2011, 12:53 AM
Sounds like it is low on fluid,does it fell like it is going into neutral?
Old 09-20-2011, 10:02 AM
it jumps into neutral out of drive... and it shifts through all gears just fine, only if i punch it it acts up.
To Power Glide, Or not to Power Glide 68Elcamino Transmission - Rearend 3 06-25-2010 06:59 AM
350 Power glide chappell Transmission - Rearend 4 03-21-2008 11:47 AM
Power Glide jmbjs Transmission - Rearend 7 04-21-2007 02:30 AM
power glide? nitro_baller4692 Transmission - Rearend 1 09-24-2006 05:19 PM
2 speed power glide APACHEMAN Transmission - Rearend 3 07-14-2003 08:41 AM
