power glide pan capacity aluminum pan - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2006, 04:32 PM
jsteve068's Avatar
i have a power glide trans with a aftermarket aluminum pan. depth from bottom of bolt holes to bottom of pan 2 3/4. need to know capacity of the pan & how far the dipstick should extend into pan area. trans leaks around pan when its full by the dipstick . thanks
Old 02-22-2006, 04:38 PM
Jmark's Avatar
If the only thing you changed was the pan, the fluid level needs to read "full" on the stick, unless you lowered the filter the same amount that the pan depth is increased. Sounds like its time to change the gasket.
Old 02-22-2006, 06:42 PM
The glide dipstick leaks a lot if not properly sealed , it uses an o-ring , I generally pull it out, use a new o-ring and put a good bead of silicone on it and stick it back in the case,tighten mounting bolt on bellhousing and let it sit overnight before re-filling with fluid. Also on the pan gasket I don't use the cork gasket I use the racing style gasket , and use a very thin film of silicone on each side when installing and also let it sit overnight and cure out , generally takes care of the problem.
Now of course you need to dry all trans fluid on pan rails and trans case before you put the silicone on it.
Your stock stick will tell you when its full , the deep pan adds about 2 -3 quarts extra I think.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Pro Topline Heads surfinca Engine 33 12-28-2008 11:37 AM
307 power glide 68 impala. 72novadude Engine 6 01-18-2004 10:35 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
2 speed power glide APACHEMAN Transmission - Rearend 3 07-14-2003 07:41 AM
