power glide or T-400? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2009, 07:47 PM
i'm building a street strip car, its a 72 elcamino it has a th400 in it, is was put in car came from factory with a th350. the trans was rebuilt or built a few years back. i bought the car from a friend. we are unsure whats in the transmission. the guy who built it said their was kevlar bands. i'm not sure if i want to rebuild the th400 or put in a powerglide. i want to use a transbrake, and i need it to hold at least 900hp. i also want to drive it on the street and ive heard the powerglide isnt very street able. im guna use a 3600 rpm stall.
Old 06-10-2009, 08:26 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
with the weight of the car , I would use the t-400.
kevlar bands means nothing... the t-400 uses clutch packs to transfer power.
Old 06-11-2009, 05:44 PM
what can the stock input shaft and main shaft handle on a th400? parts are cheaper for a powerglide than a th 400. i hear everyone talking about how good a powerglide is and all the racers run one. i need it to handle 900hp.
Old 06-11-2009, 07:20 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
My comment on car weight and use of the t-400 has nothing to do with strength of the trans.
The lower first gear of the t-400 and the 3 speeds will help the car accelerate better in my opinion.
The company I work builds glides for the area of 3,000 hp , they will work well with a big motor.
if you want a glide , get one built. Maybe a 1.80 gear set would work well for your application.
Is theis 900 hp motor ALL motor or is there NOS involved?
Old 06-15-2009, 05:05 PM
i'm looking to make 600 but the top end setup i'm buying from a friend makes 690 on all motor, i would like to be able to put a 200 shot or less on it.
To Power Glide, Or not to Power Glide 68Elcamino Transmission - Rearend 3 06-25-2010 05:59 AM
Power glide to turbo 400 71haulnazz Transmission - Rearend 3 10-14-2008 08:33 AM
400 or glide - need help choosing 406 bug Transmission - Rearend 2 11-12-2007 12:11 PM
Power Glide jmbjs Transmission - Rearend 7 04-21-2007 01:30 AM
power glide? nitro_baller4692 Transmission - Rearend 1 09-24-2006 04:19 PM
