Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Power glide to TH350
Old 10-14-2011, 08:27 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
http://www.tciauto.com/tc/trans-dim
Looks like the Glide is only 1/8" shorter, so no problem there. The Mount is about 3/16" difference, slot the Hole to fix that.
Your Glide should be 27-spline Output Shaft same as the TH350.
55-64 use 16-Spline.
