-   -   Power glide to TH350 (http://www.hotrodders.com/forum/power-glide-th350-207014.html)
69chevy 434ci 10-13-2011 12:29 PM
Hey guys I am working on a 66 impala and need to know if I need to change the drive shaft when I put the turbo in, or will the one from the glide work.
thanks John
Deuce 10-13-2011 03:31 PM
It should work GREAT !!
If you have the same length T350
GM did make a few different ones.
ethn_bert 10-13-2011 03:42 PM
X2 if it is a short tail shaft TH350
lg1969 10-13-2011 03:54 PM
I'm not sure of this. The length of Power glide and a TH350 are the same.
eloc431962 10-13-2011 04:26 PM
The tail housing is different , GM built the Th350 with 6 / 9 and 12 tail inch housings. you will have to measure the trans from end to end to know for sure. JMO
Cole
:pimp:
69chevy 434ci 10-14-2011 08:27 AM
So the yolk for the glide should go right in the turbo its just a matter of the legnth? Also i have heard rumor of possibly having to change the cross member any thoughts? the th350 is a short shaft.
SSedan64 10-14-2011 07:27 PM
http://www.tciauto.com/tc/trans-dim
Looks like the Glide is only 1/8" shorter, so no problem there. The Mount is about 3/16" difference, slot the Hole to fix that.
Your Glide should be 27-spline Output Shaft same as the TH350.
55-64 use 16-Spline.
69chevy 434ci 10-17-2011 07:19 AM
Awesome info guys thanks.
John
