It should work GREAT !!
If you have the same length T350 GM did make a few different ones.
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
The tail housing is different , GM built the Th350 with 6 / 9 and 12 tail inch housings. you will have to measure the trans from end to end to know for sure. JMO
Cole
http://www.tciauto.com/tc/trans-dim
Looks like the Glide is only 1/8" shorter, so no problem there. The Mount is about 3/16" difference, slot the Hole to fix that. Your Glide should be 27-spline Output Shaft same as the TH350. 55-64 use 16-Spline. |
| good book for glide and T-350 | psbaker75 | Transmission - Rearend | 2 | 03-24-2011 04:34 PM |
| 350 Power glide | chappell | Transmission - Rearend | 4 | 03-21-2008 10:47 AM |
| Power Glide | jmbjs | Transmission - Rearend | 7 | 04-21-2007 01:30 AM |
| TH350 vs TH400 vs Glide | GearHead69 | Transmission - Rearend | 3 | 10-02-2003 12:30 PM |
| TH350,th400 or a glide? | sleppy67nova | Transmission - Rearend | 2 | 07-06-2002 03:16 AM |
