power glide to th400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2007, 03:08 PM
hope i can get some input . i bought a 67 beaumont conv (chevelle) a while back i have since taken the 396 engine and tranny out but when i looked at the tranny crossmember its boulted to the underside of the frame with a made up spacer about 1 inch thick . from all the info i have about the car it came with a 283 and powerglide the front end has been beefed up but i would think i need to change the crossmember any sights on the web or experieance would be helpfull i looked in the tranny area but dont see anything about this subject . thanks for any help.
Old 02-12-2007, 03:47 PM
Sounds like someone has put a solid mount in it , Moroso used to make one of those things , I think.
Old 02-12-2007, 05:23 PM
Will I ever get it done?
Last journal entry: Hood
If you are talking about where the crossmember bolts to the frame.
In 67, when the mid-size GM's started getting the TH400, the frames were double drilled (non-convertible) so all you had to do was slide the cross member back to accomodate the TH400. I can't remember about the conv. frame (although I had a 67 GTO vert). I want to think it had two mounting brackets welded to the inner "boxing", but I am just not sure.
power glide? nitro_baller4692 Transmission - Rearend 1 09-24-2006 04:19 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Advise on Porta Power choice meanroy Body - Exterior 7 06-23-2004 11:38 PM
Unusual Power Steering Conversion Lars Sorensen Suspension - Brakes - Steering 17 05-25-2004 02:05 PM
68 power steering burner Suspension - Brakes - Steering 5 04-06-2004 08:20 PM
