Power-glide Turbo 350 Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2011, 12:54 PM
Hello, I am swapping out a power-glide with a turbo 350 tranny in a 55 BelAir is it recommended that I cut the lower motor mount brackets to allow more wiggle room for the swap? I am also swapping out the 6 cylinder with a small block 350 chevy motor so the lower brackets will not be needed.
Old 08-16-2011, 10:14 PM
Crosley's Avatar
Wiki Edits: 1659
so what you really are doing is an engine / transmission swap?
Old 08-16-2011, 10:23 PM
I'm almost sure you won't need to and what are you using for a crossmember
Old 08-17-2011, 07:28 AM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
my buddy and i did that swap quite a few years back and all you need are new mounts and a new cross member you don't need to cut anything
Old 08-17-2011, 12:37 PM
Thanks, just ordered the cross member and the mounts
To Power Glide, Or not to Power Glide 68Elcamino Transmission - Rearend 3 06-25-2010 05:59 AM
Power glide to turbo 400 71haulnazz Transmission - Rearend 3 10-14-2008 08:33 AM
350 Power glide chappell Transmission - Rearend 4 03-21-2008 10:47 AM
Power Glide jmbjs Transmission - Rearend 7 04-21-2007 01:30 AM
power glide? nitro_baller4692 Transmission - Rearend 1 09-24-2006 04:19 PM
