1971 chevelle will the drive shaft fit w/o having to be cut if I put in a turbo 400 with the short neck or is it off? I really haven't taken any measurements that are exact yet. They seem to be the same size for the most part but maybe not. Will it fit and whats the average cost of having a drive shaft cut and re-yolked?
You need a new front yoke. The factory used a shorter driveshaft with the TH400. Your stock driveshaft MAY fit, but you run the risk of bottoming it in the trans when the suspension moves under a hard bump.
