power and ground to fuse pannel - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2014, 03:19 PM
tapkoote's Avatar
Last journal entry: like a little kid
Hoping some one can save me a trip to the junkyard in the rain.
I got a silverado underhood fuse pannel off fleabay.
It looks like power goes to #3 &4 jumpered to #2
and ground to #1.
I can't find a good picture of it installed.
Thanks for any help.
ID:	144418   Click image for larger version
Old 05-08-2014, 05:26 PM
LATECH's Avatar
This may help.
Nope too small
Fact is stranger than Fiction
Old 05-08-2014, 05:30 PM
LATECH's Avatar
here ya go
Old 05-08-2014, 05:33 PM
LATECH's Avatar
Do you have the connectors to plug into the fuse box? and the wiring?
Old 05-08-2014, 06:28 PM
tapkoote's Avatar
I'll be making my own wire bundle.
The picture you put up has the pos but not the ground
located. Not sure what the red box is for.
Old 05-09-2014, 03:46 AM
EOD Guy's Avatar
Appears to be the starter relay. I'm not fam with your fuse box...... but the one reason for a ground in a fuse box would be to ground relays etc.... normally the coil ground would be terminal 85 or 86.... so if you box's relay slots/terminals have 85 connected together.....that might be the ground...trace it to one of the lugs.
The Following User Says Thank You to EOD Guy For This Useful Post:
tapkoote (05-09-2014)
no power to fuse block? 65CHEVELLE65 Electrical 4 10-14-2011 07:44 PM
NO power to fuse panel slider in wa Electrical 10 08-26-2008 11:46 AM
best way to put the power to the ground 67bird Suspension - Brakes - Steering 5 03-16-2004 08:18 AM
power to the ground Blag Suspension - Brakes - Steering 5 11-01-2003 09:57 PM
power to the ground 55truckin General Rodding Tech 1 08-26-2003 09:12 PM
