Power holding on stock th350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2005, 02:58 PM
Drewnashty's Avatar
sitis nam accelero
How much power can a stock th350 withstand
Hey I'll be putting a 383 stroker, which dyno'd at 440hp at 5500 and 460lbs tq at 4800, in my 76 Chev Blazer 2wd, anyway I was wondering about how much power and torque the stock th350 and rear end on that thing can handle i'm not to sure about what axle it is. I won't have access to it for about another week. I am not even sure if it is the original axle but I do know the transmission is a 350. I was thinking my engine would probably destroy the tranny and/or axle if I get on it. If that is the case I plan on just not puttin the pedal to the metal and staying easy on it until i can figure out what I should do for the drivetrain. Feedback would be much appreciated.
Old 06-26-2005, 10:20 AM
BigDawgsEatFirst's Avatar
400SBC4Life
First ,
look at ur u joints and carrier bearing make sure there good
at least rebuild ur TH 350 with stronger clutches and address the weak points with the TH350 tranny.
Rearend ?
if u dont romp and spin tires alot u should be good (rear)
but really............
u might as well start doing the rest of ur drivetrain upgrades to match ur motor
or do it after something breaks
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
how to get more power from a stock motor stoney 81ta Engine 13 12-30-2003 06:11 AM
Car Audio Question Thuggishruggish3000 Interior 14 12-23-2003 08:48 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
