Power loss in 1980 camaro
I connected the battery backwards by accident and it smoked by my alt. and by the firewall behind the pass valve cover.
Now I only get power to my headlights and interior lights. I cant crank 'er, but I can jump the starter. I have 12v running into the firewall through the red accessory wire. All the fuses look fine. What else can I check?
thats why im confused. I cant find the fusible link either.
there is 12v going into the firewall and the interior lights and such work. |
So I'll have to take my starter off then? There is not alot of room to pull wires there.
I get 12v to the starter post, I can jump it with a screwdriver, and I get 12v to the firewall. This could still be fusible links? Thanks for the help |
I searched around, no fusible links in my entire car.
Im soooo confused and aggrivated. Edit: some more goodness, the power acc. fuse terminals give no reading when connected to a multimeter while any other fuse terminals do give a reading. anyone have any tips on how to remove the fuse box and brake booster so I can figure out where the short is? Last edited by Nsomnia; 06-06-2008 at 06:25 PM. |
Heres a picure I took a couple days ago if it has any clues, I'll take some clear ones tonight. Im completly out of ideas.
Im testing for 12v at the firewall by poking the red wire in wire loom that goes into the firewall, and it gets 12v.
The two fusible links (sorry I thought fusible links were thick plastic things) also get 12v to them, and if I poke two points on them, they pass current (using a resistance meter on my multimeter). Ill try running a wire from the starter and splice it somewhere just before the firewall -> fuse box and see if that solves it. It worries me that the "power accessory" fuse does not flow any current right now, however if the fusible links are burnt out, that would explain it. I REALLY hope I dont have to take out the fuse box to rewire a fusible link in from the starter. Last edited by Nsomnia; 06-06-2008 at 07:48 PM. |
you NEED to pull that wire bundle apart and see where your main power wire (from starter) runs, and make sure that its getting power.
you /might/ have some wires melted together. I have a 79 and I when I rewired it I only remember 1 fusible link.... but for the life of me I cant remember how the alt wired into the rest of the system.....I think it merged into the power wire....After the fusible link. |
FINALLY got it.
Gave in, and ripped out the fuse box. Indeed the fusible link was fried. So I'll run a new wire from the post, through the loom, through the firewall, into the fuse box. Bolt it all back together and go back to smoking tires. Thanks for your help guys
Ill just splice the new wire into where the cooked wire leads into the fuse box on a female spade that a fuse would plug into. Im not sure where the actual wire fried. I might even try splicing it before the firewall first and hope I get lucky.
I wish I could install a simple wiring harness, routed exactly as I want, so that I wouldnt have to deal with these issues. Too much effort though, ripping apart interior, lights and engine. |
| 1980 Camaro Question | 80sCamaroChik | Transmission - Rearend | 3 | 10-24-2005 04:53 PM |
| power loss from higher ratio rocker? | KNanthrup | Engine | 5 | 08-26-2005 08:20 AM |
| 1980 camaro restoration | william27103 | Hotrodders' Lounge | 2 | 09-07-2004 09:05 AM |
| 1980 Camaro Tranny question.... | Juicer | Transmission - Rearend | 1 | 08-05-2004 07:27 PM |
| Hotrodders Knowledge Cluster: Power Steering Conversions | Jon | Suspension - Brakes - Steering | 0 | 09-03-2003 11:20 PM |
