-   -   power loss (http://www.hotrodders.com/forum/power-loss-84965.html)
skirk 03-22-2006 08:08 AM
power loss
250 in-line 6 cyl. chevy. I have rebuilt the engine, set the valves, etc. Truck will start and idle smooth, seems to be ok in first gear, however when you shift to second it seems to loose all power. Also I put a new exhaust system on it and after I put the new muffler on the exhaust pipe at the manifold is red hot and glowing after a short drive.
onovakind67 03-22-2006 08:18 AM
Sounds like the timing is retarded. What's the total timing?
docvette 03-22-2006 04:15 PM
Doc here, :pimp:
Look at your fuel mixture...
It sounds way lean..
Doc :pimp:
