power loss at WOT - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2010, 02:16 AM
power loss at WOT
on the track at WOT, after 3/4 of the quarter mile
my engine loses very smooth power. Only for about
a second ... than pulls like before???
any ideas??
its a 350 sbc with 142 Weiand and 750 DP
Old 07-11-2010, 04:38 AM
I'm sure you've checked your fuel level in both bowls already. Do you have jet-extensions on the secondary jets? What kind of fuel pump(s) are you using? I'm guessing the fuel levels are dropping enough that your jets are momentarily exposed...the rpm drops-off...and the fuel pump(s) are able to catch-up again. And that's when your power comes back. Sounds fuel-related to me. Unless anyone has other ideas.
Old 07-11-2010, 07:45 AM
Fuel level is bottom screw on front bowl, and a little bit
higher on the back one.
What are jet extensions ??
should be the stock pump (mechanical).
Old 07-11-2010, 10:09 AM
sqzbox's Avatar
My pipes are my music
Extensions screw into the jet holes and the jet's screw into the other end. It put's the jets closer to the back of the rear bowl so the jet's won't run dry from the fuel sloshing to the rear of the bowl.
Being your only having a problem towards the end of the quarter, I would guess fuel pump pressure could be your problem. If your running a Holley, stay away from the 1 fuel line into a split dual feed as the primary bowl might be taking away fuel volume from the rear bowl. Easy fix is run your fuel line into a "T" with equal length's from the "T" to each fuel inlet on the carb from the main fuel line.
Old 07-11-2010, 10:40 AM
ok, this seems to be the right things to start ...thank you
Old 07-11-2010, 06:06 PM
ericnova72's Avatar
More for Less Racer
Blown engines always require more fuel. The stock fuel pump is nowhere near big enough for the job, and I would suspect the issue is just as A1Super has said, you are outrunning what the pump can supply at higher rpm, classic symptoms.
Old 07-11-2010, 08:04 PM
sqzbox's Avatar
Man.... don't tell me that weiand is a blower!
I hate it when that happens. I feel so stupid................
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Power drops at WOT and starts rattling! tommytempest Engine 18 07-08-2005 09:57 PM
427 or 454? frankenvette Engine 50 06-05-2005 10:12 PM
Strange power loss markn Engine 9 04-26-2004 02:00 PM
