Power to manual steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2010, 10:17 AM
Pitman arm problem. I have a 76 Camaro. I recently found a manual steering box from a 66 Chevelle. The box replaces my power steering box in every way except the splines for the pitman arm. The splines are slightly smaller on the steering box. The nut is the same size. The original pitman arm is 7 inch center to center with no drop. Is there a replacement fit out there? Or will I have to have something custom made? I don't want to weld this part for safety reasons. Maybe there is someone out there who has been down this road. Thanks for any help. DrDave.
Old 07-20-2010, 06:59 PM
LATECH's Avatar
There are two size shafts. A 1 inch and a 1 and 1/8th. Not sure about the camaro box but that holds true for the chevelle box.f bodys have there own pitman arm shape so using the chevelle ( A body ) one wont do.do some comparison on e bay you may find the answer. Look for moog pittman arm or just camaro pittman arm
Old 07-23-2010, 12:08 AM
How come youre going manual? They usually have a significantly slower turning ratio which is alot less pleasant to drive.
Manual or Power Steering? scrimshaw Suspension - Brakes - Steering 2 08-15-2009 08:26 AM
Replacing power with manual steering box 1970Chevy Engine 2 11-08-2007 06:12 AM
power steering won't return to center powerrodsmike Suspension - Brakes - Steering 32 10-12-2006 08:22 AM
Replace arm strong steering to power in your 51 to 54 Chevy car Michael Bryan Suspension - Brakes - Steering 3 05-08-2004 09:50 AM
1952 Chevy car power steering box what will work? Michael Bryan Suspension - Brakes - Steering 3 04-17-2004 10:15 AM
