Power Problems? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2009, 03:54 PM
tonkaclaus's Avatar
Power Problems?
Have a '65 Galaxie. 352, automatic. Edelbrock Carb(w/spacer between it and intake), perc tronic ignition, MSD plugs and wires.
Runs great cold, great when at operating temp. BUT... Once warm if I leave it idle and build underhood temp (200-205 degrees) for a few minutes it will idle and run under light acceleration, but when calling for more than half throttle it stutters and will even backfire occasionally.
Have rerouted fuel line, new cap and rotor, new aluminum 3 core radiator & electric fan, new hoses, new thermostat, tried electric fuel pump, new water pump, new fuel lines & filter, new ignition system and back to points, tried a different coil, etc.
Any ideas???????
Old 07-13-2009, 04:17 PM
DoubleVision's Avatar
What kind of spacer is under the carb?
Blower Carb Boost Referenced power valves steve392 Engine 18 01-23-2012 12:06 PM
Power Steering line conection problems. al37ford Suspension - Brakes - Steering 1 04-29-2006 10:48 PM
'68 Camaro front brake/disc power conversion problems nathanlburns Suspension - Brakes - Steering 9 05-14-2004 08:22 AM
68 power steering burner Suspension - Brakes - Steering 5 04-06-2004 08:20 PM
Power Steering and Power Brakes blindboarder711 Suspension - Brakes - Steering 1 02-09-2004 02:54 PM
