power rack - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2013, 01:40 PM
power rack
Does anyone know whats if there is a way to change a manual mustang 2 into a power mustang 2 rack
Old 06-16-2013, 03:00 PM
cal1320's Avatar
No. You need a different rack.
Old 06-18-2013, 09:53 AM
Cal 1320 has it right... need to do a rack change to a power rack.
Old 06-18-2013, 10:02 AM
rack
so i keep my present crossmember and go to a power rack replacing the manual one. then all i have to do is figure where and how to add in the pump on my 302 HO ford?
Old 06-18-2013, 10:32 AM
spacytracy's Avatar
Last journal entry: 1957 Chevrolet 3100 Truck Small Window to Big Window Conversion
Exactly right!
Old 06-18-2013, 03:06 PM
cal1320's Avatar
If you have V belts, use factory brackets or Alan Grove brackets.
Old 06-20-2013, 09:55 AM
rack
I have one serpentine belt on a small block ford. Makes it much harder find what i need.
Old 06-20-2013, 11:32 AM
cal1320's Avatar
Is it an after market system or OEM ford serp system?
I just recently did the serp change over on my Chevy truck I used factory GM brackets and pump / pulleys. Ford has used a serp system for many years now. It might be good to hit the bone yard and get a complete Ford set up. Probably less than $75.00 or so.
Old 06-23-2013, 05:02 AM
Last journal entry: 50 Ply wagon
Just remember that the MS2 power R&P must use a 1200 PSI pump. The 79-93 pumps are a higher pressure. The GM pumps are rated at 800 PSI. So make sure you have the right pump.
Old 06-23-2013, 08:46 AM
Thankyou, I appreciate the information. If I ever get this coupe the way I want it it will be a miracle
power rack itsme Suspension - Brakes - Steering 0 03-28-2009 01:54 PM
What power rack do I have?? CamSweet Suspension - Brakes - Steering 2 05-16-2008 07:55 PM
To power rack or not ot power rack? jhanjr@swbell.net Suspension - Brakes - Steering 9 12-05-2006 10:10 AM
55 POWER RACK RICK UK Suspension - Brakes - Steering 1 11-03-2002 03:04 AM
power rack yes or no wizard1932 Suspension - Brakes - Steering 2 10-16-2002 09:30 AM
