Power rack - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2004, 10:57 PM
New Member
Power rack
Hi, I have a ford power rack on my 51 chevy, with a remote pump. The pressure is fine etc. but the system chatters when turning from lock to lock. I have tried turning from lock to lock a number of times, but still no luck. Is there any trick to bleed the air off this system, thanks, Roger.
Old 12-02-2004, 04:48 AM
jeyrl's Avatar
Thumbs down same problem
Im having the same problem. mines real jerky. jeyrl
Old 12-02-2004, 01:45 PM
New Member
rack problem
Hi, I fixed mine, I jacked up the front end and started the engine and kept turning it back and forth about 20 or more times, and that did the trick. Also some said if you take the pressure side hose off and crank the engine that would bleed the air off, take care, RT.
