power rack and pinion - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2006, 01:58 PM
propaneburner's Avatar
Last journal entry: Artillery wheels
Anybody know witch power rack and pinion will fit a 79 camaro front clip.
Like to get rid of all the old linkage.
Have checked out Flamming river, but the don't have one for my clip and my wallet is not fat enough either.
Wander.
Old 07-23-2006, 10:06 AM
There at a lot of thing to consider when selecting a rack and pinion for a conversion ... the overall length and the length of the extensions mainly. Then, the overall strength of the unit ... it is heavy enough to do the job ...
I know of no kits for your application ...
Old 07-24-2006, 07:05 AM
astroracer's Avatar
You really don't want to open this can of worms. It is not a simple job to "bolt on" a rack and pinion. Especially when you try to use a rack that wasn't designed for your non-rack suspension... There are a lot of design criteria that needs to be met to have a rack work correctly with an existing non-rack suspension. Bump steer, ackerman and turning radius are just a couple that will haunt you mercilessly. Do a search here on "bump steer" and you will find a few threads that discuss this.
Read this and do some research...
http://www.longacreracing.com/articles/art.asp?ARTID=13
You would be much farther ahead to simply put on a quicker ratio recirc. ball box and rebuild your current suspension. There is really no gain to be had with a rack and pinion that would out-weigh the problems you will create by trying to adapt one.
Mark
Power rack and pinion 1954-55 Ford Hemi Boy Suspension - Brakes - Steering 0 02-12-2006 04:16 PM
Rack & Pinion vs. Power Steering?? HELP? TheBreeze Hotrodding Basics 2 08-24-2005 08:06 PM
Mustang-II rack & pinion mounting bushings?? NASCAR314 Suspension - Brakes - Steering 4 02-08-2005 01:53 PM
92 Buick power rack pinion using 68 Ford pump? JAY221 Suspension - Brakes - Steering 2 09-14-2002 12:21 PM
power steering rack and pinion swap Paco Suspension - Brakes - Steering 0 04-03-2002 07:56 PM
