power rack question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2006, 06:35 PM
S10xGN's Avatar
Gotta love a turbo!
power rack question
Hi All,
I have a "Sweet Ryde" Corvette C4 front clip in my '47 Ford coupe. It uses a late '80's Thunderbird power rack. Can someone verify which fitting is the high pressure feed and which is the return?
Thanks!
Russ
Old 04-12-2006, 04:27 PM
Bluejackets67's Avatar
Russ,
the 16mm is the return. The 14mm is the high pressure side.
Old 04-12-2006, 07:27 PM
S10xGN's Avatar
Gotta love a turbo!
Thanks! I had a feeling the larger port was the return.
Russ
Old 04-13-2006, 05:41 AM
Originally Posted by S10xGN
Hi All,
Thanks!
Russ
I have an 84 tbird rack and a chevy pump that I reduced the pressure with a Borgeson kit. I can not recall the fitting size plus it came with some adaptors BUT I brought the parts to Napa and they made the hoses and added fitting.
There are store bought SS line but cost big money. Ed ke6bnl
Old 04-13-2006, 05:49 AM
The SS hose kit from GottaShow many cost big money, but I've used two of their kits and saved money from pulling my hair out and running all over the place.
Old 04-14-2006, 07:34 PM
S10xGN's Avatar
Gotta love a turbo!
With this setup, my pump is prolly 8" above and directly over the rack fittings. Shouldn't need much line for that!
Russ
mustang II/ thunderbird rack question sfd771 Suspension - Brakes - Steering 7 05-12-2012 08:57 AM
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 11:59 AM
Mustang II Power Steering Rack Dave42 Suspension - Brakes - Steering 7 02-13-2006 05:26 PM
Ford power rack problem? starman141b Suspension - Brakes - Steering 2 12-02-2004 01:43 PM
power steering rack and pinion swap Paco Suspension - Brakes - Steering 0 04-03-2002 06:56 PM
