-   -   power rack yes or no (http://www.hotrodders.com/forum/power-rack-yes-no-12116.html)
wizard1932 10-13-2002 06:23 PM
i have a 32 ford pickup with ifs would it be better with or without a power rack .
tm454 10-16-2002 04:54 AM
My 37 Dodge business coupe had a power rack on it. It was very sensative. I ran it the first year then changed to a manual rack, it gives me better feel of the road. :cool:
Centerline 10-16-2002 09:30 AM
Your car is light enough you don't really need a power rack, however if you decide to go with one and use a GM power steering pump make sure you use a pressure reduction valve to lower the pressure to the rack. If you don't it will be very sensitive.
Centerline
<a href="http://www.hotrodsandhemis.com" target="_blank">http://www.hotrodsandhemis.com</A>
