Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - power rack yes or no
Old 10-16-2002, 09:30 AM
Centerline Centerline is offline
Wiki Edits: 49
Thumbs up
Your car is light enough you don't really need a power rack, however if you decide to go with one and use a GM power steering pump make sure you use a pressure reduction valve to lower the pressure to the rack. If you don't it will be very sensitive.
Centerline
<a href="http://www.hotrodsandhemis.com" target="_blank">http://www.hotrodsandhemis.com</A>
