Power-Sanding to metal. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2006, 03:05 PM
User
I was thinking about doing this with my Roadster(Ford-Truck hood...), the paint is cracked really bad, and there is not really alot of metal to cover, and its mostly flat. There is alot of rust anyway, so I wouldn't be doing much more stripping then I'd have to. I was thinking of using a fine-grit sandpaper to do it, since I've heard you could scratch the baremetal too much.
I'm guessing its a power-sander, I havn't been much on paint or sanding, but its this little hand-held thing that you clamp sandpaper too shaped like a rectangle, and it moves back and forth. I helped my dad out on the Escort, and it stripped through the paint on that car without too much effort, so I was thinking it wouldn't be too hard on the hood either.
Dosn't have to be perfect either, I'm painting it from a can (Really neat Purple color from Wal-Mart, $1.50 a can...) so just enough to make it kind of nice....
-GF
Old 05-01-2006, 07:55 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Sounds like a orbital sander like the one I have in my wood shop.
They aren't very aggressive and would seem to take a lot of work
for removing paint. You really need a rotating sander to strip paint.
If that sander is all you have, try some 60 to 80 grit and follow with some
finer grit, like 150. It will work, it's just going to take more time.
If you go to the bare metal you need to prime it with epoxy.
Old 05-01-2006, 03:32 PM
User
I know I kind of sounded stupid when I first posted this, but I was just asking so I didn't ruin the Hood/Body. I have alot of time to work with, so I'm not worried about it taking too much time....thanks though...wasn't really sure about what I was doing.
-GF
Old 05-01-2006, 05:28 PM
Wiki Edits: 31
if ya got a good or fairly good compressor, get a DA sander, HF sells cheap 1's, like 30 bucks. they do a great job of paint removal.
Metal Finishing, let's talk about it. MARTINSR Body - Exterior 29 04-19-2011 08:47 PM
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 29 06-18-2009 06:54 AM
Question on Mig Welding - HOW to modas Body - Exterior 43 12-31-2005 09:48 PM
Advise on Porta Power choice meanroy Body - Exterior 7 06-23-2004 11:38 PM
Unusual Power Steering Conversion Lars Sorensen Suspension - Brakes - Steering 17 05-25-2004 02:05 PM
