Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Power Seat Switch Mounting
Old 11-28-2007, 05:00 PM
60tbirdrick's Avatar
60tbirdrick 60tbirdrick is offline
Sacred Steel
Last journal entry: The dash
Thanks DanTwoLakes, That does make sense and it is a very good idea that I will use. Can I drill through the switch plate without ruining it? The only thing I may do differently is instead of drilling holes through the switch plate, I will cut out a piece of 16 gauge sheet metal a little larger than the switch plate, drill the holes in that and sandwich the switch plate between the metal plate and the door panel. I am afraid that if I drill through the switch plate I may wreck it.
