Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - power settings for grand prix trunk latch
Old 09-14-2011, 08:59 PM
mimoose mimoose is offline
thanks guys, its a big relief to know its not too complicated.
Originally Posted by labreejr
Just run a power wire to the switch. it grounds itself when attatched to the trunk.
Originally Posted by vicrod
Typically trunk latches have an electrical release actuator. The closing latch is spring operated when the trunk is closed.
The release actuator is 12 volts DC.
The ampere draw is only a couple amps.
It only requires a momentary pulse to release the latch.
No relay required just momentary button.
Ground the body of the actuator and apply 12 volts to the wire.
