power steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2002, 10:11 PM
Post power steering
i know this is probally i simple question for alot of u.i jst put in a rebuilt power steering pump in my 65 impala.its making i whisle noise.anyone no why? also the belt is making noise when i rev the eng.i dont think the pump is leaking.if it is its a bolt in the back of pump that leaks very little.i tighteen it down.but it still does.thats for your time.
Old 12-22-2002, 11:54 AM
aka Duke of URL
Arrow
Let me see if I can help as no Chev person has answered yet...
I believe this car came through with a Saginaw pump? It's been awhile since I was under the hood of an early Chevy... <img src="graemlins/pain.gif" border="0" alt="[pain]" />
[quote]its making i whisle noise.<hr></blockquote>
  • It may be a bad pump...
  • Is the fluid level correct?
  • Have you bled the air out of the system?
  • There may be a restriction in the system...is the fluid hot after running awhile?
  • Another belt driven accessory is causing the noise...
These pumps are hard to adjust the belt tension for some and instead of either using a special tool or putting an adjusting bar where there are tabs for it, they pry on the reservoir causing leakage and funny noises as the rotor hits the reservoir or the fluid aerates as a result.
[quote]also the belt is making noise when i rev the eng.<hr></blockquote>
You mean a squealing noise?
  • You may not have enough tension on the drive belt...
  • The drive belt may be either old or glazed/covered with oil...
  • The drive and/or driven pulley may be glazed causing belt slippage...
[ December 22, 2002: Message edited by: KULTULZ ]</p>
Old 12-23-2002, 04:19 AM
Arrow
lots of good info.ty
