power steering alignment problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2006, 01:02 PM
StevenC's Avatar
I have a 1970 GMC C2500. I am converting it over to a long water pump. I have the alternator bracket mounted with the alternator. I have the waterpump and crankshaft pulleys mounted. However I am in a delima with the power steering pump alignment.
I have a long water pump, a two groove crank pulley with the waterpump and alt ont he outer groove leaving the inner groove for the PS pump.
I am using this bracket:
http://store.summitracing.com/partde...0&autoview=sku
However I cannot get my pump to line up. The pumps pulley lines up with the center of the two grooves on the crank pulley. I was told by a friend I would be able to use the trucks stock pump and it would line up fine, it does not seem like that is possible. even with the pump pressed against the block it goes not line up correctly.
What pump should I be using? off of what year and kind of car?
Old 05-27-2006, 09:06 PM
Might be easier to find a complete '69-up Chevy car or '73-up Chevy truck with a similar engine, and use the entire complement of accessories and brackets. BUT FIRST, look at the front of your heads and be sure you have the right accessory bolt holes on them. Some short-pump Chevy trucks may have a hole or two but they aren't in the right positions for the later long-pump brackets.
Old 05-27-2006, 11:12 PM
StevenC's Avatar
The engine is not the orginal engine in the truck. I am using edelbrock heads. I have everything lined up but the power steering situation and i dont know what i can do about it.
Old 05-29-2006, 12:22 AM
StevenC's Avatar
Someone has to have had this problem before.
Replace arm strong steering to power in your 51 to 54 Chevy car Michael Bryan Suspension - Brakes - Steering 3 05-08-2004 09:50 AM
Help! How do I install a new power steering canister to my existing pump? boricua_stang Suspension - Brakes - Steering 1 10-02-2003 06:48 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
Power steering problem nelsonauto Suspension - Brakes - Steering 6 01-14-2003 05:31 PM
power steering rack and pinion swap Paco Suspension - Brakes - Steering 0 04-03-2002 06:56 PM
