Power Steering Box Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2009, 07:51 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
My "89" S10's steering box needs (2) hose fittings so I can hook up my power steering. The local auto parts store said that the fittings were metric. One fitting was a 16mm & the other a 18mm. Which port is the pressure side from the pump?
Thanks
Old 02-25-2009, 04:47 AM
the high presure side is the one that has the treaded fitting the other hose most likely should use a hose clamp.l(ow side) the pump will have just one screw in fitting high side
Old 02-25-2009, 06:32 AM
S10 Racer's Avatar
I am using an aftermarket SWEET power steering pump with a remote reservoir. The pump has all threaded fittings.
I need to know which port on the "Power Steering Box" is the pressure port. Both fittings are threaded. One port is a 16mm and the other is a 18mm. I could assume the larger port is the return port to the reservoir and the smaller is the pressure port from the pump but I hate to assume anything.
Thanks
Old 02-25-2009, 07:00 AM
Can you spin it in the correct direction and see which way the fluid travels out of the pump?
Old 02-25-2009, 07:19 AM
didnt it come with distructions? thats the last thing i did when i put my MSD dizzy in my 87 was read the distructions... i didnt know about the slip ring adjustment i thought all GM type dizzy's were the same, lucky i didnt blow my motor i know it's supposted to be instructions u could always call the company's tech suport
Old 02-25-2009, 10:42 AM
He's asking about the ports in the STEERING BOX, not the pump!!!
Old 02-25-2009, 11:59 AM
*** Please post solutions ***
The 18mm is the pressure side.
Old 02-28-2009, 03:05 PM
johnsongrass1's Avatar
Race it, Don't rice it!
The one closest to the frame side is the return. The one closest to the center of the car is the pressure side.
62 Nova Steering box Question. ElguapoShoebox Suspension - Brakes - Steering 15 12-21-2010 06:03 PM
power to manual steering question. 1970Chevy Suspension - Brakes - Steering 6 02-12-2008 11:31 PM
Question on 66 Mercury Comet steering and brake issues....... onebadmerc Suspension - Brakes - Steering 5 01-11-2007 05:41 PM
Steering Box Question SKULLNICK Suspension - Brakes - Steering 1 01-08-2007 10:44 PM
power steering won't return to center powerrodsmike Suspension - Brakes - Steering 32 10-12-2006 08:22 AM
