power steering box replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2005, 02:21 PM
New Member
I have a 71 z28 that seams to over steer with very little road feel that is aslo currently leaking. I would like to replace the unit with a unit with better qualities.
My current box has 4 bolt holes on the unit but is only fastened by 3 bolts in the frame rail ( 1 upper forward & 2 on bottom. I checked the number on the top of the housing and it has 5691676 with a search i could not find this part number. I also checked the number on the front seal which is held in by a ring clip that number was 7800715 which seams to come up as a gmc 96 part??
Can I use my existing pump?
What ratio box should i be looking for?
What would be a good manufacturer?
Thanks for all the help.
Old 03-13-2005, 04:08 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Steering box replacement
Try borgeson.com they carry new stering boxes and can get you a match for most domestic cars..including options for quicker ratios..You probably have a saginaw box and your existing pump and plumbing should be fine provided those pieces are in good condition..
OMT
Old 03-14-2005, 01:55 PM
Odium's Avatar
There's a trick that if you take the guts from an '88-'90 Firebird WS-6 or '88-'91 Z-28 box and reassemble your box with those guts you'll get 12:1. I know a friend that did it and he loves it. I have all the parts and am getting ready to do it myself. I'll ask him what the exact serial # is you need and how it's done.
Old 03-17-2005, 03:28 PM
johnsongrass1's Avatar
Race it, Don't rice it!
huh... or you could just bolt the box on to the frame and drive it. Why make it hard on your selfs?
Power Steering Conversion olestufsafl Suspension - Brakes - Steering 4 11-27-2006 08:44 PM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
Power Steering and Power Brakes blindboarder711 Suspension - Brakes - Steering 1 02-09-2004 02:54 PM
Power Steering Hose Connections Larry D Suspension - Brakes - Steering 3 12-02-2003 07:06 AM
67 impala steering box bukweet Suspension - Brakes - Steering 0 12-18-2002 05:52 PM
