which power steering box to use on 50 ford coupe
need some information on replacing original steering box with later model power steering box what models thanks
Are "set" in you thinking that you have to use a clunky box sitting on the frame rail or would you consider using a rack and pinion? Neither is a drop in modification, but a R&P would possibly be the easiest as the pump would sit just above the steering, shorter hoses vs a pair that would either run back to the box or dangle down to the control valve mounted on the end of the drag link. That second set up is notoriously unreliable. The very few PS systems that Ford used, '49-'56(yes, they will interchange fairly easily), have probably disappeared from the salvage yards and replacements will be very expensive.
This vintage car steers reasonably easy though seemed to have about 20 turns lock to lock with that big wide steering wheel
| Steering and suspension for 62 Ford Fairlane Sports Coupe | d&c repairs it all | Suspension - Brakes - Steering | 1 | 09-20-2008 11:56 PM |
| power steering on 55 ford | airboy | Suspension - Brakes - Steering | 2 | 01-23-2008 09:48 AM |
| Need help with Electronic steering for my '40 Ford coupe | MichaelSporong | Suspension - Brakes - Steering | 3 | 10-27-2006 01:34 PM |
| steering column for 34 ford coupe | jaxhome | Suspension - Brakes - Steering | 2 | 09-12-2005 06:59 PM |
| power steering 48 chevy coupe | ksm | Suspension - Brakes - Steering | 1 | 06-18-2003 08:45 AM |
