Power steering control valve adjustment - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2008, 07:53 PM
Anybody know how to adjust a power steering control valve on a 1970 Corvette. The steering wheel pulls to the left when its running........all new parts except for the valve which I rebuilt.
Old 10-03-2008, 11:49 PM
Fairlane,
Point the wheel straight.
Jack the front end off the ground.
Remove the Left front wheel.
Remove the cover (about 1/2" round) on the control valve. Will pry off with a screwdriver.
Get a 7/16" socket.
Start the engine, your wheel will start turning left.
Start turning the exposed nut in one direction. The wheel will either start turning left more, or will start turning right, By turning the nut back and forth noting how far you've moved it to make the wheel change direction, turn it half way between those extremes.
Put the cap on, wheel on and lower to the ground.
Simple
Hope this helps
Dan
Old 10-04-2008, 06:50 AM
Thanks Dan, I will try it today!
Old 10-09-2008, 08:04 AM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
Did you replace the steering box? I am running a quick ratio Saginaw 700 box on my 54 and recently had the proportioning valve inside the steering box fail which threw the wheel hard left. I never knew there was a valve in the steering box. A replacement box was about $135 at the local parts house. Now everything is rock solid.
Old 10-09-2008, 09:07 AM
No I didnt replace the steering box, but just about everything else. I adjusted the nut on the end of the control valve counter clockwise and it seems fine now.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Modifying Holley baseplate so power valve references manifold on s/c motor blownS10blazer Engine 3 09-05-2008 10:21 PM
cam question, any truth to this? 406 ss monte Engine 6 03-30-2008 11:28 AM
68 power steering burner Suspension - Brakes - Steering 5 04-06-2004 08:20 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
