Power Steering Failing - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2005, 10:16 AM
On my drive in to work today, the power steering in my 94 Ford E150 van started acting up. When I turn to the left everything seems fine but when I turn to the right, it?s like I don?t have power steering. I haven?t been able to check the fluid yet. Will do that first but is this a sign the pump is failing or is the problem in the box??
Old 03-31-2005, 10:54 AM
aka Duke of URL
Most likely box failure as you have assist on left turn.
new power steering pump questions HARVICKx29 Suspension - Brakes - Steering 3 09-05-2005 03:22 PM
Power steering pump hitting box tjh211 Suspension - Brakes - Steering 7 11-16-2004 04:29 PM
Swapping to big block chevy low77ride Engine 5 09-15-2004 09:30 PM
Power steering chatter in steering wheel jpd37 Suspension - Brakes - Steering 10 05-19-2003 03:59 AM
Power Steering Pump Problem... IWasBlown Engine 1 04-07-2003 09:03 PM
