Power steering fluid? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2013, 12:41 PM
Madmax305's Avatar
I just put a new power steering pump on my 1967 Elky. I have been running GMC automatic trans fluid. Would it be worth while to run synthetic trans fluid, if so does it matter if the if the steering box still has some conventional fluid remaining? Will it be ok if the two fluids mix?
Old 05-09-2013, 04:36 AM
could have flushed the system until you are sure that fluid didn't mixed, mixing power steering fluid into the system would make some pretty mild irregular steering response, since they are different viscosities and immiscible. I seeks specialized automotive help to get through the situation.
power steering fluid douger456 Suspension - Brakes - Steering 1 01-22-2008 08:02 PM
power steering or trans fluid? runn141 Engine 10 02-22-2007 11:03 AM
ATF vs Power Steering Fluid? Jag Daddy Engine 1 12-15-2003 12:22 PM
power steering fluid andybird Transmission - Rearend 1 12-11-2002 12:12 PM
which power steering fluid? andybird Suspension - Brakes - Steering 1 12-11-2002 09:43 AM
