power steering fluid lost when 4wd engaged - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2007, 06:47 AM
Hi people i need some help on this one 1993 chevy silverado 5.7 4wd now here is the sitiuation , Yesterday i engaged my 4wd and drove to home depot 4 blocks down the road i here a whinding noise from under the hood . I pulled over to notice all my power steering fluid leaking out . I get to home depot a block later park go inside a pool of power steering fluid all gone . any one can tell me what happen thank guys !!
Old 04-09-2007, 10:18 AM
Just curious, why would you be using the 4WD in Miami (per your user ID)? If it's like the transfer case in my '89 GMC K1500, 4WD is not meant to be used on dry roads at all. BTW, the transfer case has nothing to do with the power steering pump, so I think you're just looking at a coincidence.
Old 04-09-2007, 10:22 AM
Chopt 48's Avatar
It sounds like the truck chose that time to loose a seal or hose. Or the cap on the reservoir was left off.
I don't believe there is any connection between the power steering and the 4x being locked in.
I have to agree with Mauss the 4X isn't intended or recommended to be used on dry pavement in that rig.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
56 chev power steering cols56 Suspension - Brakes - Steering 1 07-25-2005 05:06 AM
weird power steering gothrod87 Suspension - Brakes - Steering 3 06-15-2005 08:42 AM
Power steering conversion 63 econo Suspension - Brakes - Steering 4 05-23-2005 06:32 PM
