power steering gear box question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2006, 08:27 PM
all show, all go with a 383
I have a 73' chevy nova, I pulled the motor for other reasons. I removed the power steering lines and they were unfortunatly damaged.
Does anyone know, what the thread sizes are for the gear box, both supply and return and the pump, supply only. I have plans to run earls or russell's fittings and braided lines instead of oem again. But I need to know what the fitting size is to go to a -8 hose size.
Any information will be welcome.
thanks
Dan
Old 05-21-2006, 09:25 PM
powerrodsmike's Avatar
Wiki Edits: 161
Those are probably 5/8-18 and 11/16-18. You can check the threads using a regular SAE threaded bolt of the same size.
BE different....ACT normal.
Old 05-25-2006, 02:32 AM
hoses
Those Fittings Would Be 5/8" And 11/16" To -6 An Hose Adaptors, And The Pump (79 And Older) Would Also Be 5/8". Wehave Stainless Hoses With Banjo Ends For The Hydroboost, Which Will Fit On That Nova And Give Yards Ofvalve Cover Clearance
Steering box question 60tbirdrick Suspension - Brakes - Steering 4 05-08-2006 03:57 PM
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 02:01 PM
Steering box question Ratoflic Suspension - Brakes - Steering 1 04-27-2005 04:14 AM
Dumb Power Steering Question... Mike_82 Suspension - Brakes - Steering 1 03-28-2005 11:43 AM
70' chevelle power steering box rebuild kevin2004 Suspension - Brakes - Steering 2 04-30-2004 07:59 PM
