Power Steering Hose Connections - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2003, 10:48 PM
Larry D's Avatar
Question Power Steering Hose Connections
Hello,
I have a 72 Chevy Cheyenne 1/2 ton I am restoring (350 w/ TH400). The flare fitting on the power steering return line to the steering gear won't seal. I have a brand new OEM line with good threads. When the tubing nut is tightened all the way down to the last thread, there is still an 1/8" of play in the steel tube...the flare does not seat. From what I can view of the connection in the steering gear, it doesn't appear to have a flare fitting seat...it looks more like an o-ring seat. Does anybody know if some of the later model steering gears (73-78 or later) used an o-ring seal on the power steering hoses? The previous owner had many later model parts on this truck and I'm wondering if this may be a later model steering gear. There are a couple of casting numbers on the gear; 7802644 & 5686815. Any way to reference those to determine what years this gear was used in? Any other thoughts? The Chevy dealers had no info on this.
Thanks for your help.
Old 12-01-2003, 11:31 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
i can tell ya that my 84 burb has an O-ring style fitting going into the steering box
Old 12-02-2003, 07:00 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
I had the same problem with my 79 k-2500.
It has identifiable parts from 1968 through 1985.
The power steering gear on mine is an older style than everything else I have had a chance to work on until this truck came along, You may find that there should be a flare where the threaded nipple fitting rides against, then a short straight sectionabout an inch long. with a different style seal than the later fittings have. I MADE mine work as the stock fitting broke off at the nipple with the previous owners negligence.
Looking at the fittings side-by-side you cannot mistake the difference.
Old 12-02-2003, 07:06 AM
Wiki Edits: 5
and if i'm not mistaken you can get an adaptor to go from o-ring ro flare type fitting.............joe
