Power Steering hose question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2008, 09:47 PM
Something I've being wondering about. What would happen if you use nothing but steel tube for the power steering system, how would that affect operation?
Again, just curious; I heard that doing so with the a/c system lowers the efficiency.
Old 08-14-2008, 10:05 PM
The inablility to flex. Needs to be able to flex
Old 08-14-2008, 10:35 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
It has to flex. Fuel lines to the engine flex. Stock engine mounts flex. Stock body mounts flex. Brake lines to the wheel cylinders/calipers flex. Stock radiator hosed flex. Stock AC hoses flex.
In the case of my truck...the whole frame flexes. Oh...that is not the same thing.
Without some flexibility...things start cracking and breaking.
Old 08-14-2008, 11:36 PM
Never thought of that.
Good to know.
Been looking at that teflon hose for brakes and figure I could use it for the power steering as well.
Thanks for the info guys!
Old 08-15-2008, 07:27 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
I agree about flex vs. cracking, but I have found out that P/S can even be run with LONG solid lines with no apparent losses in ability to function.
We put a GM 4x4 P/S box on an old big industrial tractor with 5 foot long solid 3/8" lines. The matching GM pump is solid mounted at the front frame driving off the front hyd pump shaft, and we have not had an issue "yet". The lines are so long that flexing really does not seem to be an issue. We've run it for long periods doing excavation projects, and don't see any overheat problems either. I almost expected that, due to the flow going through such long lengths of stock size tubing that was designed for "short" distances.
On a car? I would not do it for any reason.
My first ever question, adding power steering awert Suspension - Brakes - Steering 1 02-23-2007 12:49 AM
Power steering question chrisflock Suspension - Brakes - Steering 4 02-19-2006 02:31 PM
Power steering hose, restrictor Question Joe 570 Suspension - Brakes - Steering 1 02-02-2006 07:03 AM
which power steering fluid? andybird Suspension - Brakes - Steering 1 12-11-2002 09:43 AM
location for power steering hose bracket 68mustang Suspension - Brakes - Steering 0 07-31-2002 11:12 PM
