Power Steering Hoses - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2011, 03:21 PM
Iam running braided hoses on my car an Iam running in to trouble I have the Teflon hoses on the hi pressure side with the olive fittings which worked out good but on the return side you cant because of the fitting on the pump. So can I run the 6an line that I had left over from my trans lines for the return? Any suggestions Please! Thanks Larry.
Old 11-28-2011, 03:07 AM
SSedan64's Avatar
Olive Fittings?
The Trans Hose should work, return line doesn't have any pressure, only suction.
Just make sure the Hose's Vacuum rating is high enough to prevent it from collapsing.
Old 11-28-2011, 07:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There should be fittings (banjo-style and others) to allow you to use AN fittings on the pump. Is it a Saginaw?
I'm guessing the aluminum fittings that are olive colored have been hard anodized.
http://www.purechoicemotorsports.com...=cat/cat99.htm
Old 11-28-2011, 08:39 AM
S10xGN's Avatar
Gotta love a turbo!
Originally Posted by cobalt327
...I'm guessing the aluminum fittings that are olive colored have been hard anodized...
The high pressure teflon hoses have an "olive " (similar to a ferrule in a compression fitting) that swedges into the hose to make up the fitting. Scroll down to the "P.T.F.E. Hose Assembly" section...
Russ
Chevelle Power Steering Hoses?? usa3990 Suspension - Brakes - Steering 3 10-08-2010 10:55 PM
power steering hoses smrat Engine 3 04-03-2009 02:41 PM
Advise needed for the right power steering hoses renfroe453 Suspension - Brakes - Steering 7 03-11-2009 10:50 PM
Power Steering Hoses Cole32 Suspension - Brakes - Steering 2 03-06-2006 12:01 PM
power steering hoses jeyrl Suspension - Brakes - Steering 1 08-07-2004 02:59 PM
