power steering issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2012, 09:49 AM
Last journal entry: door trim
I have a 2001 dakota and the power steering has started to feel choppy. It doesn't turn smooth any more. I checked the fluid and the belt doesn't slip. Not sure if the pump is going or the rack itself. truck has 210,000 miles and needs to keep going. any help? sc
Old 04-04-2012, 12:47 PM
kleen56's Avatar
Are we talking 4X4? If so, check the axle u joints/ ball joints. Pretty common problem on Dakotas...You can jack the front end up and spin the wheel. Now, turn the wheel while it is jacked up and try to spin it. It will probably be hard to turn. you can also grab the axle shaft near the u-joint and twist back and forth and pull up and down side to side. If there is any play the joint is bad. Not too hard to replace.
Old 04-04-2012, 01:32 PM
It is a 4x4 and the ball joints are new within the last 2years. I will check the axles for play. thanks sc
Old 04-09-2012, 08:45 PM
milner's Avatar
if the u joints are worn out, you will get some play, but if they are seized, they will be tight. look for powder rust around the seal on the caps. good luck.
power steering pump issue truckboy61 Suspension - Brakes - Steering 17 08-25-2011 05:57 PM
power steering pump issue truckboy61 Engine 3 07-01-2011 10:35 PM
Header/Steering Issue Sojo Engine 2 06-27-2011 11:46 AM
power steering pump issue truckboy61 Engine 3 06-01-2011 02:34 AM
loose steering issue 75chev4x4 Suspension - Brakes - Steering 8 02-07-2011 09:37 PM
