Power steering leak... DIY or no? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2003, 08:09 AM
I've read through previous posts but i'm still unsure of the fix.
My power steering pump on my 67 camaro is leaking from what I can only describe is the shaft coming out of the front if the pump that the pulley resides. I assume that there is some type of o-ring on the shaft that need replaced. I saw where someone said that you can buy a rebuild kit for cheap.
Can I do this myself with average skills? Would I need any special tools?
Thx in advance
Old 11-06-2003, 10:49 AM
willys36@aol.com's Avatar
Wiki Edits: 21
They are very easy to rebuild and you need no special tools. The seal is a lip seal and easy to replace. Get the kit and go for it!!
Old 11-06-2003, 11:50 AM
Thx willys! will do.
