Power Steering leaking
I have a Mustang II frontend on my 51 Chevy car. I noticed under the car some fluid? Looks to be leaking right at the steering rack where the pump lines connect too? Does the fitting need to have a crush washer or something like that. I believe there is a low pressure side as well as a high pressure side. Any help would be appreciated, I might have the wrong fitting on it? I just used a pretty anodized one from Earls supply.
Thanks |
some hoses have o-rings on them....joe
It is leaking between the steering box and the fitting? Thanks
i'll rephase this, the fittings on some P/S hosing uses o-rings, & others used a double flare at the end of the fitting.
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| Unusual Power Steering Conversion | Lars Sorensen | Suspension - Brakes - Steering | 17 | 05-25-2004 02:05 PM |
| Power Steering Hose Connections | Larry D | Suspension - Brakes - Steering | 3 | 12-02-2003 07:06 AM |
| Power steering chatter in steering wheel | jpd37 | Suspension - Brakes - Steering | 10 | 05-19-2003 03:59 AM |
| Power Steering Pump Problem... | IWasBlown | Engine | 1 | 04-07-2003 09:03 PM |
